Emission/pcv hoses
Emission/pcv hoses
I've tried searching breifly, but haven't readily found generic emission/pcv hose that is oil resistant. It's all heater hose. I may be not searching properly....
I'm looking for 1/2" & 5/8" ID hose. The coolant hose doesn't last too long with oil going through it.
Bump....anyone??
tturnpaw
Post by tturnpaw »
summit racing has hose that is oil resistant. Check them out.
Hmmm.....I looked, but maybe I didn't look hard enough.
RJ93SS
Post by RJ93SS »
silicone intakes has silicone lines, unfortunately i think they're biggest is 12mm/just under 1/2"...
but, if you email them they might have something, i tried calling for my order, could never get an answer though
tturnpaw
Post by tturnpaw »
Ive always had braided lines made at a fitting shop we have here nearby. Ive seen the issue happen many times with our project escort. We were using summit racing's hose and sandwich adapter. The hose would get brittle as our stock valve cover hoses do. But braided lines do the trick. If these would be a part that would fit all of our cars, i may even consider doing a group by or something for braided lines.
Florin1
Post by Florin1 »
I just went to my local "Action Auto Parts" store and they had both diameters. Its called, "emission system hose" or "smog hose". It was cheap too. Like 1.50 a foot. Guy told me it will handle oil/gas. All the other parts stores "napa/schucks/auto zone" couldn't help. You may also wanna try a diesel performance shop. Or a place that works on semi's.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Thanks for the comments guys. We don't have any action auto parts stores around here. I'll have to call around to a few auto parts stores.
Grayguy
Post by Grayguy »
Napa has it too I believe.
92' SS: SOLD
Florin1
Post by Florin1 »
napa had only 1/2" And was like 3.50 a foot. Its a smaller thickness but stiffer. I didn't like it because it was hard to work with and expensive. And they dont carry 5/8 or 3/4
I should have spotted this thread sooner. Go get hydraulic hose like Weatherhead and the like. Go to diesel truck shops. They often have oil rated hoses in those sizes.
Heater hose ftl.
