Moderators: Helpinators , Moderators
fatgc8
Posts: 214 Joined: Fri Dec 19, 2008 5:48 pm
Post
by fatgc8 » Tue Jan 26, 2010 5:31 pm
I was wondering if anyone has a pinout of a 91 ss tps sensor. Im doing a swap and that's the only thing keeping me back from starting this thing. Any type of help would be great.
2005 STi (500WHP with "SlowSTi" as the license plate lol (Weekend Warrior)
1991 Legacy ss JDM EJ20G swap with STi goodies (DD)
kleinkid
Posts: 1213 Joined: Fri Jan 24, 2003 3:39 am
Post
by kleinkid » Tue Jan 26, 2010 8:36 pm
Maybe this will help you. Someone else will probably have better/more for you.
brown=idle switch 1
black=ground 2
red=power 3
white=signal 4
Please follow up on what you do in regards to the TPS. I may/probably be going to face the same issue.
fatgc8
Post
by fatgc8 » Tue Jan 26, 2010 8:59 pm
Can you tell me what the idle switch 1 does please?
Posts: 3242 Joined: Mon Oct 16, 2006 9:44 pm
Post
by ericem » Tue Jan 26, 2010 9:58 pm
Tells the ECU the throttle is closed and to idle?
Posts: 27934 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Tue Jan 26, 2010 11:26 pm
