hydraulic clutch swap
funkentelechy
Post by funkentelechy »
I am planing on replacing the clutch in my beloved 94 legacy 5spd. I've been looking around and I like the gear ratios of some of the newer gt's and rs's that have the same fd ratios, and It's a lot more easy to find a used low mileage transmission from the newer models. From what I understand subaru switched to a hydraulic clutch after 96, does anyone know if I can make a hydraulic clutch transmission work in my cable clutch car? Do I need to convert my car to a hydraulic clutch system, or can swap out the release fork? Any input would be greatly appreciated. thanks
"Everythang good is nasty and it ain't no good unless you play with it"
Welcome,
Yeah you may need to move the pivot ball on the transmission. There should be two bosses in the transmission, one will be for the hydraulic setup, one will be for the cable setup.
You can see what I'm talking about in this pic
http://www.surrealmirage.com/subaru/ima ... P_3077.JPG
funkentelechy
Thanks that's very help full!
