hydraulic clutch swap
Posted: Sun Feb 07, 2010 6:47 pm
I am planing on replacing the clutch in my beloved 94 legacy 5spd. I've been looking around and I like the gear ratios of some of the newer gt's and rs's that have the same fd ratios, and It's a lot more easy to find a used low mileage transmission from the newer models. From what I understand subaru switched to a hydraulic clutch after 96, does anyone know if I can make a hydraulic clutch transmission work in my cable clutch car? Do I need to convert my car to a hydraulic clutch system, or can swap out the release fork? Any input would be greatly appreciated. thanks
