So what makes a phase 2 5MT different from a phase 1?
Just curious if someone can educate me on this matter. Phase 2 began with '98 model year, correct?
Todd
2002 Legacy GT Wagon 2.5/5mt
1999 Legacy Outback Limited Wagon 2.5/4eat(wife)
1998 Forester S 2.5/4eat
1972 Buick Electra Limited 455/TH400
1988 Jeep Grand Wagoneer 360/TF727
Most of the differences are in the tail section. Refinements to the center differential design and bearing layout, and some differences in the shaft layout (all fairly minor). The synchro design was also revised to give much smoother shifting, but the design is significantly less robust than the phase-1 synchro.
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
Re: So what makes a phase 2 5MT different from a phase 1?
Is this an accurate observation, TY752=phase 1 and TY754=phase 2? Seems to be the case as far as I can tell.
Todd
For the most part, yes. But there are TY753's as well - almost all of which I've seen are P 1. However, I'm not sure that's a hard and fast rule - I did see one that had a phase 2 center diff, so they may have been an in-between phase. I believe the 753's are only found in MY 97-98, but definitely not all 97-98's are 753's (most are 752's).
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
