I have a 1996 Outback 2.5 Dohc Legacy (JDM, OBD 1) that I picked up for $800NZD (about $400 USD) it is really tidy but had a blown head gasket (as they do).
I also just happen to have a 1991 Legacy GT (JDM, ej20 dohc) that is totally unwarrantable but also happens to have a mint motor and turbo (VF11).
It can go around in circles in the paddock all day on boost but im quite willing to sacrifice it to build a little more power into the outback.
After reading the posts on the forum for about the last two years and looking at other peoples builds I dont think it is totally unconceivable that I could transplant the turbo, water to air intercooler and other bits of plumbing off the legacy and try to give it that little tiny bit of forced motivation.
The interesting part about the Outback I have is that it appers to already have a bit of the turbo car influence upon it (for example it has a notched x-member and a downpipe type exhaust setup?!?)
My real concerns are:
Oil feed for the turbo
Being able to prevent the turbo from producing more than about 4psi.
Timing
Fuel
I figure with this little amount of boost I can probably get away with a lot, RRFPR seems like a good idea but Im not even sure it is necessary.
I know it may not even seem worth the effort, but you know - i already have most of the bits as far as I can tell (except the oil feed)
So my questions are:
Where would be the best place to get a feed for the turbo? (keeping in mind I have the whole turbo car)
Will timing be an issue with 4psi?
Will I need to worry about the injectors/fuel pump?
Obviously if i wanted loads of power I could just swap the motor and loom from the turbo legacy, but really, loom swaps are just a massive headache and all I really want to do is add a little to the top end and perhaps a bit of torque for towing. The fact that I would have acutally got a turbo running in the thing will be the pay off for me (im a tinkerer)
My thinking is that as long as I loose no air (pumb back BOV) and run very little boost then I probably wont have to worry much about throwing off the MAF and ECU.
The turbo car has all the original Subaru pipe work including the plastic baffle that stops the maf getting confused by the air rush from the plumb back BOV.
Obviously I am rebuilding the 25 motor, new headgaskets, head bolts, water pump etc etc.
Any assistance would be greatly appreciated, between you all you seem to know about all you need to know about these cars
If I can get it all to run okay and not explode within a few thousand kms then I will probably look to moving to a link or emanage but at the moment it seems like a lot to spend when it may not be completly necessary.
