some intake line questions.
nicv217
Post by nicv217 »
So im getting the subie back together and i need help with some of theese line... the gas lines in picture 1 i have no idea where they go to and from... and the nipples in picture two i have no idea what they are for also..ive scoped the service manual and forums and cant find any info.thanks everyone
A (the top hose) goes to the fuel filter. B and C are the return lines and C is a smaller size so you shouldn't get them mixed up.
in the second pic, the top nipple is for the line that goes to your brake booster... don't recall the bottom one tho
cj91legss wrote:in the second pic, the top nipple is for the line that goes to your brake booster... don't recall the bottom one tho
No, that's not correct. I think you may have things mixed up.
ciper
Post by ciper »
IIRC -
A is supply
B is return
C is vent
Blue spray paint is ugly
brweber352
Post by brweber352 »
ciper wrote:IIRC -
A is supply
B is return
C is vent
Correct
93'TLegWag171k StockBlock,TD05,HallmanMBC,530cc,Walbro255,shortram,LWpulley,DIS-2,MSDcoil,cxrFMIC,trans cooler/external filter,WRX wheels/brakes,CES w/Borla muffler,QTP elec cutout,REVchip2,KYB GR2,GroupN tops/all fr bushings,STImounts,GSD3 tires,LM-1,etc
brweber352
That sure looks like the booster fitting to me, the one under it should be BPV vacuum/boost source.
It's not. It's the fuel lines.
Legacy777 wrote:It's not. It's the fuel lines.
He is talking about the second pic. Looks to be the brake booster top and BPV bottom. The TOP pic is for the fuel lines.
brweber352
yup
Ah BPV see i haven't looked at those two in so long...
My bad....didn't look closely enough at the picture. You are correct.
