quick question .. moving up-size flywheel
N1446
Post by N1446 »
i m replacing the clutch and flywheel from oem 2.2T to 2.5N/a
does this mean i need a different starter or will i use the original starter ?!
N1446 Brutus
91 Legacy SS 5mt 2.5GT Swap
You can't do that. The transmission clutch types are different. The 2.2 turbo trans uses a pull type clutch setup, while the 2.5 n/a uses a push style clutch setup.
To my knowledge they are not interchangable.
N1446
Post by N1446 »
ok i may have worded the op incorrectly
what i mean to say is that i have a EJ2.5 in the car now using a 22t flywheel and clutch assembly the 22t flywheel and clutch are a smaller size then the ej25 setup yess ?!?
the 22t clutch has burnt up , i m wanting to change up the size to a larger diameter flywheel - clutch
if i go wrx ej25 that is a pull-type clutch, do i need the wrx starter for the ej25 or will the one for the 22t that i have now mate with the larger diameter flywheel ?
N1446 Brutus
The actual outer diameter of the 2.2 flywheel should not be any different when compared to the 2.5. The surface mating area of the clutch is what is smaller/larger.
With that said, you should be fine with your existing starter.
N1446
Post by N1446 »
rigght onnn,
i have a limited supply of parts available here
i really need to re-locate !
appreciate it
N1446 Brutus
