quick question .. moving up-size flywheel
Posted: Tue Mar 02, 2010 12:54 am
by N1446
i m replacing the clutch and flywheel from oem 2.2T to 2.5N/a
does this mean i need a different starter or will i use the original starter ?!
Posted: Tue Mar 02, 2010 4:21 am
You can't do that. The transmission clutch types are different. The 2.2 turbo trans uses a pull type clutch setup, while the 2.5 n/a uses a push style clutch setup.
To my knowledge they are not interchangable.
Posted: Tue Mar 02, 2010 5:43 pm
by N1446
ok i may have worded the op incorrectly
what i mean to say is that i have a EJ2.5 in the car now using a 22t flywheel and clutch assembly the 22t flywheel and clutch are a smaller size then the ej25 setup yess ?!?
the 22t clutch has burnt up , i m wanting to change up the size to a larger diameter flywheel - clutch
if i go wrx ej25 that is a pull-type clutch, do i need the wrx starter for the ej25 or will the one for the 22t that i have now mate with the larger diameter flywheel ?
Posted: Tue Mar 02, 2010 7:44 pm
The actual outer diameter of the 2.2 flywheel should not be any different when compared to the 2.5. The surface mating area of the clutch is what is smaller/larger.
With that said, you should be fine with your existing starter.
Posted: Tue Mar 02, 2010 8:06 pm
by N1446
rigght onnn,
i have a limited supply of parts available here
i really need to re-locate !
appreciate it
