Auto tranny shifting from 2nd to 3rd feels like no go?
Hey guys, seems like if I take off rpm's hovering around 2500-2700 from 1st to 2nd car is accelerating,but once it hits third I feel I need to give it more throttle and get the rpm to 3k+ before it starts accelerating furthermore. It is very annoying because I jump right into boost and waste gas for no reason. Also in general the shifts are very soft. I am debating swapping another transmission AGAIN!! But, I am thinking adjusting the brake band is a good idea. Would adjusting the brake band possibly help fix this issue with soft shifts and not fully engaging? Also going to try trans-x tranny additive!
I would start with the brake band. It controls 2-3 shift I believe. Sounds like it needs to be tightened. Here's the adjustment procedure.
http://main.experiencetherave.com/subar ... andadj.jpg
You may just need to tighten it a little at a time until it shifts better.
Re: Auto tranny shifting from 2nd to 3rd feels like no go?
I am going to try out the trans-x additive first. If there is no change I might as well screw around with the brake band as I will be swapping in another transmission most likely. It seems difficult to hold the square nut and loosen the locking nut. I don't want the brake band changing when I loosen up the lock nut.
bry
Post by bry »
i've noticed the same effect on a 1990 i recently worked on. 149k miles, 2-3 is sluggish, and then suddenly starts to accelerate like someone had stepped on the gas. to me, feels like a valve not completely shifting in its bore until pressure is built enough to force it. i changed the fluid (probably the first time ever as it was a little dark, although not having an akrid, burned smell). will see if that helps in a few months. it's not my car, so feedback will be slow.
have another friend with a 1994 and 330k on the original auto. no problems 2-3.
keep us posted on your band adjustment.
