I am building a 2.35L DOHC frankenmotor and ran into interferance between the crossover pipe form a STi and the front crankcase vent on the ej22t block.
I was thinking of plugging the vent with a freeze plug. I have had friends that did this on 2.5L STi hybrid motors and are running fine...but I'm a little more paranoid with my build.
Can deleting this vent cause any problems? I know the 2.0L WRX motors don't have this vent at all. The DOHC heads I am using only have one breather fitting on them.
Plugging the front crankcase vent....OK?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
Re: Plugging the front crankcase vent....OK?
It should be fine since you are using those heads.
plug it ! my first dohc motor was swallowing oil, my second motor i built is still running like a bull for 3years 25psi and beat the crap out of it, with out any problems.
sorry you mean the under alt vent right center block ? if your talking that one then yes plug it.
Yup...the one under the alternator. Good to hear there should be no problems...should clean up the clutter a bit.
maciek puszynski
16 WRX | 6mt | fa20
16 WRX | 6mt | fa20
i believe it's purpose is to even out crankcase pressure with the pressure in the heads. it doesnt run to the intake anywhere. take a look at the wrx and sti setup to see if the back line is the same as ours, maybe there's are different?
