Engine: EJ22T
Tranny: 5 speed
No CEL or anything stored codes
Mods/Things done engine wise:
-3" Divorced DP
-2.5" straight back (with a cat, no muffler)
-Desnorked
-Kn'N panel filter
-Knock sensor was replaced sometime before I had it so between 120,xxx and 130,xxx
-Valve cover gaskets, Turbo oil outlet hose, Turbo up and down pipe gaskets, exhaust manifold gaskets @ 131,708
-Agency Power Light weight crank pulley @ 134,169
- NGK/NTK 02 Sensor @ 135,793
-Engine Ground mod w/ 8 gauge wire @ 135,837
-NGK plugs and wires and PCV valve @ 136, 629
- Swapped the Greddy EBC with a Halman MBC @ 137,841
-Replaced coolant Temp Sensor @ 140,397
-Oil replaced every 3-4k miles with Mobil1 10w-30 and Napa Gold filter since Ive had it
I believe thats it. Now the issues with the car
-The needle on my boost gauge flutters under boost
-Also flutters at idle between 15-16 sometimes 15-17 inHg
-Cold starts are fine but I was having problems with warm starts, replaced the Coolant Temp. Sensor and it seemed to fix that issue
- Gas mileage sucks! I average about 15-16 mpg
- When accelerating it hesitates... Like you accelerate and it just wont go and kind of surges and than once it hits 3k RPMs it throws you in the seat and takes off, almost like crazy turbo lag but its at full boost from 2250k
- Also the 90*elbow into the turbo cracked awhile ago, so I silicone it and than electrical taped it
-Also when accelerating it has a whistle or hiss and its not the turbo whistle, its different and louder
-Idle fluctuates nothing crazy but you can watch the needle go up and down as the boost gauge needle flutters
-Backfires (mostly because of the straight pipe exhaust
Ive sprayed carb cleaner around vac lines and such and havent had any luck. I do have RevScan now, so I can run a log but Im not sure what I should be looking for.
I checked the Resistiance on my Coil Pack today just because as I was reading about intake/vac leaks and it mentioned a bad coil
- Primary Resistance: between 1-2: .9 ohms 2-3: jumped between .8 - (1.1) ohms
- Secondary Resistance: 1-2 = 21.7k ohms and 3-4 = 21.5k ohms
Oh and when I was messing with the RevScan my octane factor was at 100%, whatever that means
I believe thats it for now. I just would like some help diagnosing and finding out what the hell is wrong with my car. I want it to run like a champ, plus autocross is coming up!
Matheww044's car has 170+k miles, sat for a year we pretty much have the same mods and his car hauls balls..and mine doesnt. Id like to fix that! (I knew I shouldnt have sold that SS
- Much Thanks In Advance
