OEM o2 sensor
OEM o2 sensor
Is the OEM sensor a wideband or narrow band sensor?
Re: OEM o2 sensor
There might be something useful to you here http://bbs.legacycentral.org/viewtopic.php?f=11&t=43096
Re: OEM o2 sensor
Well if the OEM is narrow, I was just going to replace it with a wideband that also has a narrowband output to keep the OEM functionality but still be able to keep tabs on the AFRs
