creak in front end
jeffrhomola33
creak in front end
Post by jeffrhomola33 »
okay so i got a 1991 legacy and some times or most of the time when i start or go over a bump my front end will creak! don't sound to healthy so just wonderin wats wrong or how to fix it :|
Re: creak in front end
Could be springs or possibly a ball joint.
Try pushing down on the front end and see if you can reproduce the squeaking noise.
jeffrhomola33
k thanx! il see what i can do
Or bushings, or spring dampers. I'd look for a worn-out rubber part first.
