piston pin plug-cap allen wrench size ?
Posted: Sat Mar 13, 2010 5:11 am
by N1446
as the title states ^^
the piston pin cap is much bigger than the clutch fork pin cap ..
what size key is it ?
i m taking the 22T case apart this weekend .. it looks pretty bad inside..
Re: piston pin plug-cap allen wrench size ?
Posted: Sat Mar 13, 2010 5:19 am
by SLODRIVE
It's 14mm. I use a long 9/16" nut from Ace Hardware, works great.
Posted: Sat Mar 20, 2010 3:21 am
by 206er
also you can double nut 2 14mm head nuts on a short 14mm bolt which you probably have lying around. then in a 14mm socket of course.
Posted: Sun Mar 28, 2010 6:40 am
by N1446
never thought of that
i love ghetto Garage !!
Posted: Sun Mar 28, 2010 10:26 pm
by SLODRIVE
I tried the double nutting, and failed miserably. :( the plugs were in way too tight for that in my case, I guess.
