as the title states ^^
the piston pin cap is much bigger than the clutch fork pin cap ..
what size key is it ?
i m taking the 22T case apart this weekend .. it looks pretty bad inside..
piston pin plug-cap allen wrench size ?
N1446 Brutus
91 Legacy SS 5mt 2.5GT Swap
Re: piston pin plug-cap allen wrench size ?
It's 14mm. I use a long 9/16" nut from Ace Hardware, works great.
http://www.slodriveracing.com
-And more!
-And more!
also you can double nut 2 14mm head nuts on a short 14mm bolt which you probably have lying around. then in a 14mm socket of course.
never thought of that
i love ghetto Garage !!
N1446 Brutus
I tried the double nutting, and failed miserably.
the plugs were in way too tight for that in my case, I guess.
![Sad :(](./images/smilies/icon_sad.gif)
-And more!
-And more!
