Intercooler Mounting
Front, Top, Air, Water.
How are you guys mounting your intercoolers? I noticed there are mounting tabs on them but I don't have the proper brackets to bolt them to. Will they fit my engine if I find some off a WRX using a 06-07 TMIC?
Are you guys even mounting them or just hooking up the hoses and calling it good?
dscoobydoo
Re: Intercooler Mounting
Post by dscoobydoo »
I think a lot of people are not using the brackets. Simply since you would have to fab your own brackets.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Really? Even if you're using DOHC heads and intake? Mine came with brackets but I think they only fit the EJ20G intercooler which doesn't fit under my hood. I would think you could probably buy some brackets off a WRX that should fit.
Mattheww044
Post by Mattheww044 »
yea, I just make sure the throttle body hose clamps are safely tight, if all the hoses are tight, and the hood is closed, its not going anywhere. It would be nice to have it clamped down just for peace of mind, but its nothing Im too worried about.
SLODRIVE
Post by SLODRIVE »
I've been running for the better part of a year with nothing holding up my TMIC besides the hoses. No problems whatsoever, I wouldn't worry about it at all.
http://www.slodriveracing.com
-And more!
Alrighty then, thanks lol.
wtdash
Post by wtdash »
SLODRIVE wrote:I've been running for the better part of a year with nothing holding up my TMIC besides the hoses. No problems whatsoever, I wouldn't worry about it at all.
+1
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
martimus919
Post by martimus919 »
Same here
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
I'm gonna play the geek's advocate here.
Yes lots of stuff works. That is a given.
Optimal is a situation that hold the IC in place, yet allows for expansion room. Rubber feet are great. Yet, TMICs are tough to implement that. Take it as you see fit....
gijonas
Post by gijonas »
If you use a tight fitting hose and T-bolt it to the throttle body it is perfectly fine.Not only that but you have the y-pipe underneath giving it support as well.Our engines move around a lot with torque and bumps,the intercooler should move with it rather then stressing the hose connection or the IC body itself.
You really need something to support the back side or the sides of the intercooler. That's why the stock setups have the extensions that come up from the transmission. Then everything moves as one piece, engine, trans, intercooler...
gijonas
Post by gijonas »
That i see working,i was assuming the thought people might have was making brackets that attach to the firewall or something.
No I would never attach it to the firewall lol. I put up a wanted ad on NASIOC but those guys want too much money for them.
oldscoobyturbo
Post by oldscoobyturbo »
I would suggest trying the stock airbox brakcets from a 2.5 na engine like a forester or impreza. you can attach it to the pitch mount area and its already the correct shape etc..
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
kleinkid
Post by kleinkid »
That is a sinful suggestion.
kleinkid wrote:That is a sinful suggestion.
Is that good or bad?
To expand on the topic; How do those of you running AWICs mount them? I would think that the extra weight of the water would put more stress on the TB coupler, if that is all that is supporting it.
I made a bracket to support the AWIC core. You've got to have something back there to support it. The TB won't do it.
Here's some pictures of the braket I made. I need to move it down slightly because the radiator cap hits the hood.
http://www.main.experiencetherave.com/s ... es/td05/03
