Im looking to get rid of my 94 Touring wagon. It runs great, had 195k miles, lots of body issues, dent in fender and quarter panel, rust in typical legacy areas, leaking power steering rack, and tranny slipping from 1st to 2nd. Engine runs strong and I had the timing belt and water pump and seals replaced in Dec. 08. Interior is clean. Also sunroof leaks on drivers side in heavy rains. Tires are Toyo Proxes 4 225/55/16 mounted on 16 inch 2001 wrx wheels. Tires have about 10k miles on them and still look and handle great. I also put two new drilled slotted rotors on the front last summer along with new akebono pads. All four calipers were replaced in 07, and car has stainless brake lines on front and rear as well as drilled slotted rotors in rear also. If the body didnt need so much attention, I would invest more money in it, cause its been a great car. I bought it in 3/2006 with 140k on it. Heat shields just started rattling too. $900
Dan
203 206-6406 cell
94 Turbo wagon
94 Turbo wagon
95 Svx 75k miles
98 Outback Limited 142k miles
06 LL BEAN 115k miles
Re: 94 Turbo wagon
got any recent pics of the car??
is this the car??
http://bbs.legacycentral.org/viewtopic.php?t=33174
is this the car??
