Contol arm removal help
drsevy
Post by drsevy »
I've removed the control arms on the rear from the sub frame and have removed the nuts on the foot long bolt which holds the two to the hub/wheel on each side. What I can't seem to do is remove the contol arms on this side. Both ends seem to have the bushings "frozen onto the bolt.
Anybody have some tricks or hints to rmoving them ?
I actually got one of the 4 off but the center of the bushing metal piece stayed behind on the bolt !
95 Legacy L Wagon Silver 5speed 265K miles
95 Legacy L wagon Maroon Auto 135K miles
96 Legacy Outback Wagon Auto 215K miles
67 VW SC Pickup 35K miles
80 VW Diesel Dasher Wagon 212K miles
90 Chevy Z71 4 X 4 91K miles
90 Toyoto Camry 205K miles
Re: Contol arm removal help
Are you talking about the inner side of the lateral links that bolt to the subframe?
Use a lot of pb blaster.
drsevy
Post by drsevy »
No, the outer ends of the lateral links that have the big bolt that goes through both of the links.
Were you able to remove the bolt, or is that the issue? If you can get the nut loose on the one end of the bolt, leave it on a little and then give it a good whack with the hammer, and then use a punch to continue moving it through the hub.
