Hi,
my friend is going to swap out the auto in my '98 LGT and swap in a 5mt for me, I figured that before I put the new trans in, I might as well put new bushings into it etc. Any thoughts on the best bushings to use and a source for purchasing? Super excited about this project, the end result should be sweet. Thanks.
							Doing a trans. swap, best bushings to use?
1993 Legacy L AWD 5-sp wagon
						Re: Doing a trans. swap, best bushings to use?
What bushings are you looking to swap out?  Only trans related, or suspension?
You could get the STi hardened rubber trans mount. I'd also suggest the Kartboy front and rear stay bushings.
