What Front Spring Pearch?
Florin1
Post by Florin1 »
Update---> In the FAQ it says i need front upper spring pearches to make my 05 wrx struts work. What model are they from, or what part number? Anybody know?
So i came across a decent deal on NASIOC on some Koni's off an 05 RS. My questions are, will these fit straight across? Buyer is throwing in rear sti tophats too. Comes with springs too. Should i use the ones it comes with or use my current H&R springs. Here is the ad and actual pictures.
http://forums.nasioc.com/forums/showthread.php?t=195455
Update:
1.Picked up my Shocks today. Here are some things i noticed which i hope someone on here can help me with. If i compress the shock(s), it does not rebound. It can be full soft or full hard. When i pull the rod/cylinder up there is a difference in how easy or hard the rod comes up depending on setting. The shocks don't seem to be leaking because the inserts are dry. The shocks only have 30K on 'em. So... Is this a normal Koni feature??
2. The spring rates on the Prodrive springs are 240F/ 200R. Is this a good rate for our cars?
Any input would be appreciated. Thanks
Update 3: Koni doesn't rebound back by itself. Thats what Koni Tech told me.
1994 Legacy Sport Sedan.
1991 Legacy Sport Sedan.
Florin1
Re: Bough used Konis. Anybody else have Them?
Post by Florin1 »
Bump. Anyone??
Florin1
Re: Bought used Konis. I have some q's?
Post by Florin1 »
Ok so in the suspension FAQ it says if i want to convert my suspension to 02+ wrx i need "FP = Front Upper Spring Perches". My question is, From what model??
