I'm just playing with all the blocks and cranks I have laying around. Most likely someone has done the same thing but I thought I see it the 2.2L crank fits the 2.5L Phase I block? It does fit but with the 2.2L rods the pistons fall short of the deck by around 2mm. So is the 2.5L rod slightly longer? I use the nearly flat top Phase II piston I figure the CR will be close to the original 2.2L
Has anyone played with this set up?
2.5L with a 2.2L crank
rally370
Cheers
Chris
Rally Legacy AWD #370 gone! Rally Suzuki swift GTI N1 #370 parted out. Now Mini Cooper #370 with STI suspension in Costa Rica
Chris
Re: 2.5L with a 2.2L crank
I have heard of people destroking the 2.5L with good results.
The 2.2L crank will fit the phase 1 2.5L.
The phase 1 2.5L rods are 1.1mm longer then the 2.2 rods.
The 2.5L rod journal is 48mm and 2.2 is 52mm.
Phase 2 2.5 SOHC rod is longer then 2.2 rod....I don't kow by how much
The journal diameter is the same on those
Might look into 2.2L crank, phase 2 2.5L SOHC rods and custom piston?
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
what is the goal with destroking a ej25? more revs? its already an oversquare engine.
rally370
The idea was just to see what fits what. I figure there is a ton of Phase I blocks laying around with no cranks and even more complete 2.2L as donors. If it was just simple case of dropping the 2.2L crank/rods in the 2.5L phase I block it would be a cheap conversion for 2.2L owners.
Cheers
Chris
Chris
the_watts10
http://www.techworkseng.com
you need to look at this website they have a 2.5na motor kit destroked to a 2.35 with ej20 rods making suffiecent horsepower i would assume!!
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
