rear brake line connection
drsevy
Post by drsevy »
The steel rear brake line from the rear wheel (right rear seems to head up into the body in front of the gas tank.
Where is the connection exactly. I need to replace the steel line from the rubber hose forward and don't want to simply make a patch piece.
thanks
95 Legacy L Wagon Silver 5speed 265K miles
95 Legacy L wagon Maroon Auto 135K miles
96 Legacy Outback Wagon Auto 215K miles
67 VW SC Pickup 35K miles
80 VW Diesel Dasher Wagon 212K miles
90 Chevy Z71 4 X 4 91K miles
90 Toyoto Camry 205K miles
Re: rear brake line connection
If you remove the rear seat you will see where it enters into the car. There is however a union where the brake pipe in the car mates up with the rear brake piping. It should be just in front of the gas tank
You can kind of see the union in this picture
drsevy
Post by drsevy »
Thanks Josh - You just saved me a lot of time :)
welcome :)
