Throttle Body Seals??
92 Rally
Post by 92 Rally »
We did a boost leak test a while back and we had a HUGE leak at the throttle body seals (butterfly shaft seals). I was wondering if anyone had a part number for these things? They appear to be replaceable with some effort, but if I can not get the seals then I wont waste my time taking it apart any further.
[b][color=white]-Ryan-[/color][/b]
"We live for a good time, not for a long time." -Colin Mcrae
[url=http://wrxmodders.com/forums/viewtopic.php?t=15103]Project RallyX: 1991 Turbo Legacy[/url]
gijonas
Re: Throttle Body Seals??
Post by gijonas »
Interesting,i never gave that area a thought before as a source of leakage.Makes sense.
RJ93SS
Post by RJ93SS »
the orange piece, is that the seal you mean? maybe hightemp silicone could fix that?
It's not a replacable part from Subaru anyway. You could try and find a seal, but TB's are a dime a dozen really. So I'd recommend just replacing the TB.
92 Rally
Post by 92 Rally »
My issue with replacing it with another used one is that it might leak as well. I will try a few things on this one before I go and buy a used one.
That is true, but I wouldn't say it's a common point of failure. I swapped around TB's a while back and never had any issues.
jefferson
Post by jefferson »
I would unstake that outer washer and then remove the seal. You should be able to measure it and use those dimensions to get a new replacement from a bearing house or seal specialist.
Jeff
92 Rally
Post by 92 Rally »
We were gonna do just that but them washers are in there GOOD! I am just gonna clean it good, grease the seals, and slap it back on.
