at temp light on
scoobylover57
at temp light on
Post by scoobylover57 »
my at temp light comes on at start up and never turns off. i replaced the sensor and its still on. there is no other lights on on the dash. any ideas? thanx.
-Nick-
91 lsi with ej22t swap. work in progress. Sold.
92 SS 5spd. stock. Sold.
94 TW. 6 spd. V2 sti ra ej20g. 550's. rob tune.
94 SS 5spd. stock
Re: at temp light on
Your TCU is throwing a code of some sort. Read the code and go from there.
scoobylover57
i forgot to say i tried that to there is no codes in the tcu.
-Nick-
94 SS 5spd. stock
Please post the the year and model car.
scoobylover57
its a 91 lsi. with a ej22t swap and a 92 auto turbo tranny.
-Nick-
94 SS 5spd. stock
What trans computer are you using? One for the turbo legacy tranny, or the one for the 91 lsi?
Has the light always been on since you did the swap, or just recently?
If you have replaced the sensor, there may be a wiring problem. I would also suggest you check the trans codes to see if anything come up. I have instructions on my site.
http://surrealmirage.com/subaru/trans.html
