No spark issue
No spark issue
So I've checked the ignition relay, coil resistance plug wire resistance. But the plug that goes to the igniter or ICM does not show voltage on the two signal wires like it should
Re: Where is the ignition relay?
It is a green relay in the upper left area behind the dash. I've been told you can get at it without removing the dash if you reach from the other side of the steering column.
It's easily done with out removing anything if you've got mad tyte stretching and flexing skills. I can do it in literally 15 seconds, but I cant tell you how I do it...one of those things you have to figure out on your own.
92' SS: SOLD
Actually it was a brown relay about 6 inches above the fuse block ...I removed the fuse block and it was pretty easy to reach and once I did I pulled it through a hole in the dash for easier access...but that. Wasnt the problem I'm still not getting spark
