EJ25 DOHC heads vs. EJ20? DOHC heads advice needed.
logan9691
Post by logan9691 »
I know this has probably been covered before but I need some advice. What would be better for a stock EJ22T short block (stock internals ect.) EJ25 DOHC heads or EJ20? heads from a wrx or JDM legacy? Let me know waht you think.
Thanks.
Logan
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: EJ25 DOHC heads vs. EJ20? DOHC heads advice needed.
There's a lot of threads out there with good information. The earlier EJ20 heads are going to be the proper way to go...
