Ej20g?? emissions?
91legacyawdturbo
Ej20g?? emissions?
Post by 91legacyawdturbo »
Hey guys just wondering if anyone has had any issues with an Ej20g to pass emissions??
I'm currently running as much stock as I can. Stock exhaust, recirct bov, new plugs oil change stock boost levels. New O2 sensor coolant temp sensor, Is there anything I should do before I head out to get this done???
Thanks Brian
2002 wrx sport wagon
PhyrraM
Re: Ej20g?? emissions?
Post by PhyrraM »
As a safeguard, I would run the stock EJ22T injectors, MAF and ECU. After that, I don't forsee any problems.
91legacyawdturbo
Yeah I'm running stock but the injectors don't fit into a g rail I'm running the g's 440s thou
91legacyawdturbo
Epic fail!!!! Burning way to rich. Thinking because of the 440s so I'm thinking of finding a set of g rails for a templet and take my old 380 tleg rails and have the mounts reversed for the intake an just run the 380s in it. Does anyone have a spare 20g rail or intake manifold that I may borrow it rent for a few days????
