Trans swap pedal question
I know this is a gen 1 forum, but I'm looking to find out what pedal assemblies will work to swap into my 98 Legacy GT wagon that is getting a manual trans swapped into it in place of the auto. Any help would be greatly appreciated.
1993 Legacy L AWD 5-sp wagon
Re: Trans swap pedal question
What type of clutch setup are you planning to use? Cable or hydraulic. That will determine what pedal assembly you will need.
If you go hydraulic, you should be able to use the pedals from an mid 90's Legacy or Impreza.
