Namely I need the stock radiator support clips that rest on top of the radiator and tie into the car just behind the grill. I'd like them to have the rubber grommets as well but it's not a requirement.
Second, I need the electrical connectors from two radiator fans with a healthy pigtail of wiring. I'm wiring in some low profile fans and would like to utilize the stock harness and not hack it up.
Please let me know if you have any of this and can help me out. It'll be supporting a brand new cool Koyo alum. radiator if that matters
Thank you in advance.
