91 saggy butt shims and one unit spring perch and strut top
chochocho
Post by chochocho »
hello all,
i am looking into getting those saggy butt shims for the rear of my 91 ss. it has the one unit strut top and perch.
i plan on ordering some extender nuts so that i can install my rear strut bar. does the rear strut top/perch allow for it?
thanks in advance.
Bdub
Re: 91 saggy butt shims and one unit spring perch and strut
Post by Bdub »
I have the 1" thick shims, and I was able to get the bolts snug to the studs without any issue. If you add a strut bar, you probably won't have an issue. It seems like there was still enough of the studs sticking out.
Also, I used a tile cutting bit on a router to zip out the holes, and shape the shims to the shape of the 91 tophats. I'm not even sure which ones I ordered, but the holes weren't even close.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
