20mm or 22mm front swaybar with 20mm rear swaybar?
I currently have STI suspension on my 91 SS along with a whiteline BSR17XZ 20mm adjustable rear swaybar. I'm ready to buy the front swaybar now but I'm not sure if I should get the 20mm non-adjustable bar or the 22mm adjustable bar.
Re: 20mm or 22mm front swaybar with 20mm rear swaybar?
you should just go with the adjustable.. I have no area of expertise whit suspension, but adjustable sway bars are pretty cool. and you can mess with it to get a good feeling in your ride
Excellent, I'll order that right now. Thanks guys!
