Will these wheels fit on my 91 without sticking out too far or hitting the STI struts I have? If so what size tires should I use? I'm thinking it's probably too wide seeing as how most 17" rims at 7.5" for these cars.
Product Details: *NOTE FOR FORESTER FITMENTS: This specific offset requires a 3mm to 5mm spacer depending on suspension specs*
Wheel Style - Rota DPT
Wheel Diameter (Inches) - 17"
Wheel Width (Inches) - 9"
PCD Bolt Pattern - 5x100 & 5x114 (dual drill)
Offset - 42mm
Hub Bore - 73mm
Color - Gun Metallic
Rota DPT 17x9 42 offset?
