Uneven carbon build up between cylinders
dayno
Post by dayno »
Hey guys,
Doing a standard rebuild of an ej22. There is uneven build up of carbon in cylinders 1 and 3 compared to Cylinders 2 and 4. 1 and 3 have a much larger amount of carbon.
What causes this?
is it running rich in these cylinder?
How can I rectify the problem
Any suggestions would be great
Cheers
dayno
91 Liberty EJ22 auto BLOWN HG. :( FIXED
91 liberty rebuilt EJ22 5mt swap, Starter button :D
Re: Uneven carbon build up between cylinders
It's possible that the injectors for these cylinders are flowing more. Or it may just be due to how the air flows through the intake into the heads and combustion chamber.
Where are you seeing the uneven carbon build up? On the pistons?
dayno
Post by dayno »
This isn't really something worth chasing up is it.
Thanks for the info josh.
