Cylinder 1 and 2 not firing....
Posted: Wed May 19, 2010 5:15 am
by scoobyleg1
I have a 93 turbo legacy wagon and I just recently put it back together from replacing the trans and rear diff. Come to find out.. I got the wrong rear diff. So i took it back and now im looking for another one..
Anyways.. I go to start the car and its missin like crazy. Cylinder 3 & 4 are the only ones firing. I have checked all the wires and fuses and cant fipnd anything wrong. I dont no where to look next. Any advice?
Re: Cylinder 1 and 2 not firing....
Posted: Wed May 19, 2010 12:09 pm
by evolutionmovement
Bad coil.
Posted: Wed May 19, 2010 5:38 pm
As Steve indicated, it's likely a bad coil. I'd also check the wiring from the coil to ignitor and ignitor to the ECU.
Posted: Wed May 19, 2010 9:49 pm
by scoobyleg1
Ive tried 3 different coils and 3 different ignitors. still same thing..
Posted: Thu May 20, 2010 6:29 pm
Have you checked your wiring? If you've checked the coil & ignitor and still have the problem, it's either wiring or possibly ECU.
Posted: Mon May 24, 2010 5:01 am
by scoobyleg1
Fixed.. wiring to Ignitor.. :=)
Posted: Mon May 24, 2010 4:51 pm
Good deal
Posted: Thu Jun 10, 2010 9:06 am
by jeffrhomola33
WHERE is the igniter? i have a similar problem
Posted: Thu Jun 10, 2010 6:47 pm
