Cylinder 1 and 2 not firing....
scoobyleg1
Post by scoobyleg1 »
I have a 93 turbo legacy wagon and I just recently put it back together from replacing the trans and rear diff. Come to find out.. I got the wrong rear diff. So i took it back and now im looking for another one..
Anyways.. I go to start the car and its missin like crazy. Cylinder 3 & 4 are the only ones firing. I have checked all the wires and fuses and cant fipnd anything wrong. I dont no where to look next. Any advice?
Re: Cylinder 1 and 2 not firing....
Bad coil.
As Steve indicated, it's likely a bad coil. I'd also check the wiring from the coil to ignitor and ignitor to the ECU.
scoobyleg1
Ive tried 3 different coils and 3 different ignitors. still same thing..
Have you checked your wiring? If you've checked the coil & ignitor and still have the problem, it's either wiring or possibly ECU.
scoobyleg1
Fixed.. wiring to Ignitor.. :=)
Good deal :)
jeffrhomola33
Post by jeffrhomola33 »
WHERE is the igniter? i have a similar problem
It's between the red horns in this picture.
http://main.experiencetherave.com/subar ... P_2514.JPG
