Axle Boot
josh_90_leg
Axle Boot
Post by josh_90_leg »
Idk if this is in write forum subject, but my passenger side axle boot is tore all the way around and was wondering how bad that can end up being if not fixed, its been that way already for about 500-1000 miles, and there a quick easy fix?
Re: Axle Boot
If the axle has been exposed to the elements, it really needs to be replaced. It will eventually fail start clicking, etc.
If you're trying to get by for a little bit, you can buy split boots to put back on. As I said, eventually the joint will start clicking, and need to be replaced.
07Evolved
Re: Axle Boot
Post by 07Evolved »
go ahead and replace the entire axle..much easier to fix and better in the long run
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
