newly gone through ej25 heads with cams and cam shafts $300 shipped
cleaned, re-toleranced, valves reseated and completely cleaned...all done by a shop. i also have the timing belt, an ej25 dohc block that needs a little work on one half (the previous owner must have stripped a headbolt, then retapped it too large, so it will have to be welded shut then retapped. also the full dohc ej25 gasket kit. let me know what you need! located in green bay wi
(WI) dohc ej25 heads, cleaned and reseated
rally2.5rs
Straight roads are for fast cars, curvy roads are for fast drivers
Re: (WI) dohc ej25 heads, cleaned and reseated
do you still have these heads? pics?
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
2005 AW STi
2010 LGT (hers)
Build Thread
