Sure enough, if you try to open the door from the outside it's not locked. Additionally, from the inside with the door closed, if you try to push down on the lock, there is a lot of resistance and it won't lock. The only 'fix' is to use to automatic locks unlock and then lock from the driver door. That'll almost always fix the passenger door.
Now a similar issue with the driver door. Once again, using the automatic locks from the inside, I'll lock the doors (driver door is open). I can see the driver lock appears fully closed. Close the driver door, try the handle and sure enough the damn thing is unlocked! Only way to 'fix' it is to put the key in the door and turn it left and right, to once again engage the automatic unlock/lock function. This issue doesn't happen all the time either, as I now make a habit of checking the doors before leaving the car.
Whats the deal with my locks?
