97 turbo leggy project almost done
Posted: Mon Jun 07, 2010 3:44 am
by subbieedude!
Re: 97 turbo leggy project almost done
Posted: Mon Jun 07, 2010 4:37 am
by Grayguy
Is this just the stock ej22e motor? I've heard of some of them taking quite a bit of abuse with just a rising rate and low boost.
Posted: Mon Jun 07, 2010 4:42 am
by kimokalihi
What diameter up pipe is that? Looks pretty big. I think you want to keep that at stock diameter for optimal velocity and spool up.
Posted: Mon Jun 07, 2010 4:46 am
by subbieedude!
yeah its a stock ej22e. and the up and dp are both 2.5 inches. idk why it looks so big in the picture.
Posted: Mon Jun 07, 2010 6:08 am
by kimokalihi
I think the stock inside diameter of the up pipe is like 1" maybe 1.5". I don't know how much of a difference there will be.
Posted: Mon Jun 07, 2010 6:17 am
by 93forestpearl
kimokalihi wrote:What diameter up pipe is that? Looks pretty big. I think you want to keep that at stock diameter for optimal velocity and spool up.
When going cheap, optimal is not necessarily part of the equation, so splitting those hairs may not be necessary.
I have no doubt it will make boost. Hopefully you have a way of adding fuel. Anymore details on your setup?
Posted: Mon Jun 07, 2010 1:55 pm
by subbieedude!
haha it wasnt made to be a performance machine. i just didnt have any smaller piping laying around. im just doing this cuz for fun. details are...
ej22t heads
ej22t injectors
ej22t waterpump
apexi neo
aem eugo wideband.
stock ej22e bottom end
ebay wastegate set at 4 psi
turbo is a tb0363 from and older volvo. comparable to a vf11
btw the neo isn't part of the 500. i had that before i started this
Posted: Mon Jun 07, 2010 3:16 pm
by kimokalihi
That's crazy, your fuel lines stick up super far above the manifold. I dunno if they're like that stock on the EJ22T but on my EJ20G they're the same level as the manifold.
Posted: Tue Jun 08, 2010 12:04 am
by subbieedude!
aha idk why they do that actualy. those are the lines that came with that manifold. also i tried to start it up today but the ecu isnt turning on. idk if i have the wrong ecu or if is dead. is there any real way to tell what year the ecu is from?
tanks
Posted: Tue Jun 08, 2010 12:35 am
by subbieedude!
good newss.. i tried starting it with the 25 ecu and she fired right up. not for long tho just wanted to see if she would start. but open DP is friggen louddder then i thought.
Posted: Fri Jun 18, 2010 1:19 am
by subbieedude!
SHES FINALLY RUNNING THE WAY I LIKE. currently on 5 lbs. so far it beats a 93 saab 9000 cse/aero conversion, a stock legacy with an ej25. EWG is kinda annoyying. i might run it back into the exaust to quiet things up a bit =]
anyone with questions?
Posted: Fri Jun 18, 2010 2:25 am
by Florin1
yes. my question is... where is the video lol
Posted: Fri Jun 18, 2010 4:14 am
by subbieedude!
ahaha ill get one up soon dont worry =p and some more pics
Posted: Tue Jun 29, 2010 4:06 am
by subbieedude!
update....
heres my 97 legacy gt and my friends integra ls having some fun
fmic needs to be mooved over a smidge =[
Posted: Thu Jul 15, 2010 10:43 pm
by crispy93
a local. i like it.
