1990 legacy after market ecu, HELP!!
mick112
Post by mick112 »
hey guys, im located in australia and have a 1990 legacy gt wagon. im at the stage now where im looking to get a after market ecu for the car so i can make some good power. the problem is im finding it hard to find anything that i can bolt in as a stand alone system. Everything seems to be for wrx or 93 on wards. i wanted to run a apexi power fc, can anyone help me out with a part number or tell me weather the 92-96 wrx apexi power fc will fit in my car? id much rather have something that i can just plug and play as im not too keen on running a universal piggy back because the price to wire in the system.
Re: 1990 legacy after market ecu, HELP!!
Someone chime in on the Autronic. I'm pretty sure its PnP and they're in Australia, I believe.
Link ECU, Autronic, and Power FC are options. I'm not sure you'll find anything in terms of stand alone ECU's that is 100% plug and play. You may have to make some changes to how the sensors are setup, or setting up a tune.
However you may have more options in Australia.
