my car has a blader issue
LOL every time i hat the gas hard my car pee's on itself. the rear window washer squirts on the window when i do a high speed take off.
Hot damm that was fun!
1999 Legacy L postal, RHD
Re: my car has a blader issue
Sounds like the rubber pump attached the rear window fluid washer bottle may be degraded. I'd suggest pulling the rear washer bottle out and then pulling the motor. It should be able to be disassembled and you'll probably see the problem.
