I'm pretty sure I have a malfuncioning expansion valve.(Compressor engages, High pressure goes to about 360psi, low drops to <25 psi. and clutch cuts out either from hi or low pressure cutout)
I need to change out the expansion valve. Can someone steer me to a reference with diagrams for getting to and changing the valve. I'm sure I can get there with a sledge hammer and crowbar
Any help would be appreciated!
