Need help piston ring size??
church207
Post by church207 »
ok i have a little problem cant figure out i orders a piston ring set for 91-94 legacy turbo and the rings i got cam with a 1.2 top ring and 1.5 second ring now the piston i taken out has a 1.5 top ring and a 1.5 bottom ring and i cant find a ring kit that has a 1.5 top ring any body know about this and the letter on the piston is B if that matters thanks
Re: Need help piston ring size??
Welcome to the BBS.
Do you have any of the subaru manuals? If not, I'd suggest checking out this thread
http://bbs.legacycentral.org/viewtopic.php?f=12&t=14485
I've got the engine portion of the service manual on my server. It will likely have some more info on the exact piston specs, which may help you.
If you don't find what you're looking for, post back.
