VTO to 50/50
Front, Top, Air, Water.
logan9691
VTO to 50/50
Post by logan9691 »
I have a Synchronic BOV and I considering getting an APS 50/50 BOV cause I'm tired of the poor drivability of the car. Has anyone ever run an APS or similar dual vent BOV before on our cars? Does it help some of the drivability issues that come with a traditional VTO BOV?
- Logan
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: VTO to 50/50
I'm sure a 50/50 BOV will improve drivability over a true atmospheric BOV, but it's still likely to give you some issues since you are venting metered air to atmosphere.
logan9691
Re: VTO to 50/50
Post by logan9691 »
Very true, I am thinking that under normal day to day driving, not driving like an ass, it will help considerably since I would be under light load mostly so it would be recirculating more then venting.
