ive searched around and cant seem to find anyone with similar problems, anyone able to give me an idea of where to even start looking?
Strange boost/vac gauge readings?
Mikerthebiker
so i just installed a VDO boost/vac gauge in my car and seem to be getting strange readings, boost seems to be working normal. but at idle the needle sits calm at zero, if im reving or cruising under around 2000 rpm the gauge goes down to about 10in/hg. and once the turbo kicks in the gauge reads about 6psi. all in all the car idles/drives fine...
Re: Strange boost/vac gauge readings?
On my car the boost gauge reads around 18in/hg on idle I believe and probably around 0 on cruise and hits boost around 3-3.5K under decent load. I don't know if that's normal or not though lol.
gotta be a bad boost gaugeMikerthebiker wrote:so i just installed a VDO boost/vac gauge in my car and seem to be getting strange readings, boost seems to be working normal. but at idle the needle sits calm at zero, if im reving or cruising under around 2000 rpm the gauge goes down to about 10in/hg. and once the turbo kicks in the gauge reads about 6psi. all in all the car idles/drives fine...![]()
There might be a leak near or in the boost gauge line...double your fittings and lines.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
16 WRX | 6mt | fa20
Double check all the fittings, but I'd also suspect a bad gauge.
Sphinxmunkey
Try swapping it to a different vacuum line for the reading.
Mikerthebiker
so just doubled the lines and found a crack, replaced a few of the hoses and moved the gaugee line to just off 1st cyl intake manifold, and am now reading 20in HG
thanks for the help guys!
