EJ22T head parts ID
OddBallRacing
EJ22T head parts ID
Post by OddBallRacing »
So, I'm doing the 'ole "EJ22T heads onto the EJ18 block and turbo it trick."
There is something bolted to the back of the passenger side head that is NOT on my EH18 head, as well as a hole in the head below the mystery item in question.
Mystery item:
Mystery hole:
Stock EJ18 head:
Any insight?
Thanks!
Re: EJ22T head parts ID
Hint: your turbo will need oil and coolant.
Josh222
Post by Josh222 »
screwdriver is over the oil feed and the hole in the second pic is the oil drain but its missing the elbow
92 Touring Wagon Mica Black(sold)
99 Outback Limited(sold)
05 Outback XT Limited
OddBallRacing
OIC so, the top port where my screwdriver is is the port that feeds oil to the turbo and the bottom port of the same mystery item is the coolant feed to the turbo?
The mystery hole is the oil return from the turbo and I'm guessing then that the coolant from the turbo goes to the coolant tank eh?
Thanks!
Yes, you've got it correct.
