Swap advice?
Gray Ghost
Swap advice?
Post by Gray Ghost »
Hi all! So I sold the '09 STi due to financial difficulties. My beater was a '93 fwd auto legacy L with 130k I got from my Aunt. It is now my DD. Since I can't leave anything alone this was clearly to be no exception. It now has '07 sti springs, '02 wrx seats, '02 wrx wheels, and a bunch of misc. maintenance stuff that needed to be done. I stumbled across a '91 legacy lsi awd with an ej22t and turbo auto tranny swapped in. The motor has 120k and the tranny is toast. Doing a compression check tomorrow to see if it has any issues. Picking up a '98 RS 5 speed transmission, pedals, rear end, axles, slave cylinder and some other odds and ends. Swapping in the ej22t, 5 speed, awd into the '93 because it is in really nice shape. Is there anything else I should know/lookout for/pickup?
Thanks!!
Re: Swap advice?
Take a look at my swap write-up, www.surrealmirage.com/subaru/swap
I've got some good info about electrical issues that need to be addressed.
Gray Ghost
Re: Swap advice?
Thanks! Good writeup.
