AWD and FWD 5mt difference
dayno
Post by dayno »
Hey All,
I have just finished auto to 5mt conversion. All is working well but I now feel like a new challenge. I would like to swap to AWD. I found a awd of the same year that i can get the parts from cheap.....
The only problem is the donor car is an auto......
I would like to keep the manual as i just did the swap...
What are the differences between the fwd 5mt and the awd 5mt.
Can I take the rear case off the fwd 5mt and connect to the transfer case of the AWD?
from what i have read from service manual there doesnt seem to be much difference.
Is the gearing different?
Has anyone else done this before?
Thanks in advance
91 Liberty EJ22 auto BLOWN HG. :( FIXED
91 liberty rebuilt EJ22 5mt swap, Starter button :D
fishbone79
Re: AWD and FWD 5mt difference
Post by fishbone79 »
Josh (Legacy777) has a good writeup on his site detailing his AWD conversion. Off the top of my head you won't need too many MT specific things, just:
- A 5MT trans - you can't swap the rear-half on without changing all the gears and the diff - definitely not worth it.
- MT 4.111 rear diff
- AWD MT trans cross-mbr (I think there are slight differences)
- Driveshaft
- Shift linkage?
Everything else for the swap should be AT/MT independent.
*Edit* I just saw "Liberty" in your sig... Gearing was funny down there, so I hear... You should double check the gearing of things before mixing and matching.
Oh, and If you happen to find the famous hi-low AWD MT transmission in your searches, I will pay you to ship it to the states ;)
Cheers,
morgan
1992 Legacy BF
You will need to get an AWD 5MT trans. I know you just did the auto to manual swap, but if you want to go to AWD, you'll need an AWD trans.
I've got a good write-up and parts list of what's needed on my site
www.surrealmirage.com/subaru/swap
