so I need front rendlinks to replace my worn out stock ones. I dont want to spend an arm and leg cause im only running the stock front sway bar, but I want something decent that will hold up to auto x. polyurthan is a plus.
so how are the whitline steel units? for $70 seems like a pretty good deal to me but are they any good?
Honestly. I just want to replace the bushings in the stock link, the front link SHOULD be solid other then the bushings, but the rear link might have some flex. The bid will go up on that ad and who knows how cheap that aluminum or cast is.
I have them on the front of my car. They do help a bit, i istalled them initially on the stock FSB, then with 22m Railltek one, and i am very pleased. I think its $80 well spent.
94' Legacy L Wagon
~96xxx miles
~ISC Coilovers
~Whiteline RSB, Endlinks, HD RSB Mounts
~Rallitek FSB
~02 WRX Wheels
~DIY Interior (In Progress)
